I’m wondering if there’s a way to repath all Vray assets in one shot. I’ve upgraded a computer and need to remap all assets to the ‘D’ Drive. Is there a way to do this without having to address each asset/map individually?
Thanks!
Thanks!
You can achieve this using the V-Ray File Path Editor.
1. Access the tool via the SketchUp menu Extensions > V-Ray > File Path Editor
2. Make sure the listed file assets are grouped by directory
3. Select all missing assets (marked in red) of a single directory, click the Repath button and choose the new valid location of the image files.
For more info, visit
Thank you! Being able to select multiple files is helpful, but I suppose there isn’t a way to point everything to a new location? For example, the folder structure is the same, but I need it to point to the ‘D’ drive instead of the ‘C’ drive. Is this possible?
There is no way to achieve such a change to all assets without scripting it in Ruby. Even then, the solution would need to exclude assets from the V-Ray preset material library. The recommended workflow is to use the File Path Editor.
Kind regards,
Peter
