New GPU, latest drivers, Vray RT still asking for newer drivers?
Can anyone help with this error? At this moment, can’t use Vray RT on GPU at all and I would really like to test it out. I believe this card is supported and the drivers are current, so I’m not sure why this error is coming up.
Hm I am not sure what your driver version is from the screenshots. There is something like date which is from 2015, which is strange. The latest ones 362.52 from here Driver Details | NVIDIA are from 2016. Can you try with them or check your driver version from the nvidia control panel (this nvidia control panel is app that comes with the drivers, you should be able to find it from the start menu or something).
Best,
Blago.
Correct, both of you ^^
Those are the latest HP drivers for nvidia cards, but are quite old indeed (347.52).
You will need, as Blago said, the latest directly from the hardware maker (they generally just work, no worries.).
Wanted to thank you both, this did work. I think I had the latest “certified” drivers, but they were quite old. Thanks!
