New material bitmap viewport display issue
Hi, in recetn V-ray version 5.10.06 I have an troubles with displaying of new created materials with bitmap assigned.
After applying material to object, the object turns white and I need to disable/enable bitmap texturein diffuse slot to see it in rhino viewport. I recorded it.
54iyWpX
Hey @pavol_pastork ,
You’re right, sorry for the inconvenience. It seems to be fixed in our internal nightly builds, so it should be out with a future update. Thanks for the pointer!
Hi @nikoleta.garkova ,
thanks for the info.
I just want to mention that the bitmap will dissapear even when I rename the material in Asset Editor. 8)
This is also working as expected in our internal builds, but thanks for pointing it out so we could double-check it. It should be fixed with the next update, so stay tuned.
