Hi there,
Here is my set up:
AMD Ryzen 7 3700X 8 core
Processor 3.60 GHz
32 gb RAM
I’m using Corona and C4D for few months now, I had the opportunity to work on a big project ( full furnished house and garden )
My scene is about 1gb with almost 1m of polygons, could the problem come from there?
thank you
The file size on disk is not what counts, it is how much memory is used at render time (once all proxies are turned into real geometry and all textures are loaded, etc.) Are you getting a low RAM warning from Corona? Which version of C4D and Corona are you using? How much RAM does Corona use (no need to do this if you actually have the low RAM warning as you already know that’s the problem then
Otherwise, you can check in the render stamp, see https://help.c4d.corona-renderer.com/support/solutions/articles/5000522226-renderstamp-variables for the list of variables you can add, and see the Frame Buffer Settings tab in the Render Settings dialog for when to enable and edit the Render Stamp). Is it slow with other scenes, or just this large one?
