I built my desktop with a custom water loop. It was pretty easy and it’s been totally quiet and maintenance\leak free. I run waterblocks on my GPU and CPU. Both are overclocked and run very cool and stable. Pretty nice.
I started with a custom kit and swapped out parts I felt needed upgrading such as clamps, the CPU block and the tubing. It was still cheaper than buying everything (radiator, pump, reservoir, etc) separately. Also never add anything to your water, just use distilled and get a silver coil in the line. Works great for 2 years now!
We’ve mostly built our own machines in the past, but I’m not sure we will again in the future. Not enough time to troubleshoot issues that always arise from systems that aren’t fully tested. Yes, you will save some money, but I’d keep my eye out for a ready-built Dell machine (or similar) safe in the knowledge that if it doesn’t play ball, you can get it sorted quickly.
I also build mine in the past but stopped. When something goes wrong you have all the trouble indentifying and replacing the broken part.
that can be quite annoying and timeconsuming. I let mine build by alternate, an online shop. They have a PC Configurator where you can
choose exactly the parts you want. They´ll build it and you can optinal order a two day stress test. Also you´ll get warranty for the system.
If a part doesn´t work in the setup, they´ll contact you with alternatives.
Btw. The new x99 chipset for the next intel cpus that will come out in september will support 64gb ram on release and 128gb later.
So it really might be worth waiting.
Interesting idea. A colleague recently got a new Dell machine - I forget the model. Its an amazing bit of kit. Absolutely solid and puts my ‘hand-made’ builds to shame!
You can use Asus motherboard. Those server grade mothersboards are very different to Desktop. It might be a scary change for you. Asus ones are a lot more delicate…
I’d be cautious buying game rigs for work In this one, no mention of motherboard? I couldn’t see it anyway. I’d rather spec it out by parts, research each one then have some one (store) put it together for you.
Maybe it’s just me but I never thought it was worth it spec’ing higher clocked ram (ignoring OC’ing). Everything I’ve read leads me to think it might only give a couple of percentage points increase, if that. Anyone?
