What is it?!
On all my render nodes/
It’s associated with warning massages for DR?
Now I have going to press /Cancel/ on all my render nodes?!
yes---- perhaps not enough physical memory, but for this exist virtual memory and paging file, and do not need to remind this every time I hit /RENDER//
Do you know in which daily build it started happening?
Can you capture a 3dsmax minidump when the problem appears? https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006 )2)
just tried and it is not happening here - can you post the minidump?
Here in attachment
For render this scene Corona used 7.10 GB of physical memory
On slaves exist 8 gb physical memory/
Why Corona not use Virtual Memory and page file of the system?!
This situation not so critical for error massages and crashes/
3dsmax_minidump.dmp (6.15 MB)
Corona cannot decide how much physical memory it will use. This is decided by OS. It is impossible for a single process to use whole physical memory.
the minidump says there is crash inside distance sub-texture of a Corona AO texmap… is it the same problem as the one with screenshot? Because it seems like entirely different problem
ok, can you give me minidump for THIS moment, where THIS message is on screen?
BTW: if you are having any crashes with Corona AO + distance texture, you can send us scene and we will investigate that one too… but the problems are probably not connected.
Minidump file is created only when Max crash/
But my slave not crash, it just shows me this message and freeze the render process/
I want to say that this problem is not only the scene but also with
several others where there is no AO texture.
but which render close to 8 GB of physical memory/
How can I send you my scene?
Its 229mb file size
You can upload it via Corona’s private uploader: Renderer for architectural visualization - Corona | Chaos
you can create minidump from any process - see https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
OK
here is it
And Scene file via Uploader
FileName:HanukaBooks22.zip
3dsmaxDUMP.zip (12.8 MB)
the popup should be fixed in todays daily
Thanks very very MUTCH!!!
