The on/off-flag of Render Elements is not recorded on The new Render Setup (2016 ext2 Or later).
V-RayMaya 3.40.04 is not supporting new Render Setup?
There is something strange going on with the render elements. In general, it would work if you use the “enabled” attribute and add an absolute override (for example) while on the new layer. We’ll look into improving the behavior.
Thank you.
Additionally, AOV support of Render Setup is hoped.
It is supported, actions are simply not recorded properly. But it works if you use the actual “enable” button of the render element node when it is in a collection and an absolute override is added.
