New Renderlayer system with vray_adv_36001_maya2018_x64_27689 + Maya 2018 Update 1
I?m evaluating maya?s “new” renderlayer system (again) in order to check if it fits our vray workflow.
Right now I?m having Problems with the render elements.
I can add them to a layer via “create absolute override for visible layer” in the attribute editor on the extra vray attribute of the specific render element.
In order to get an actual override in the new render layer editor i have to repeat this step for each render element as doing it once just adds the element to the AOVs Collection of the active layer.
Without the repeating step the Y/N selection in the render settings → Render Elements Tab doesn?t work either.
Is this intended? Do I really have to repeat this step for every new layer I create when I don?t want to export every element in my list?
Another big Problem is, that it seems impossible to remove/delete the Elements from the render layer. (rightlick → delete does not work)
Is there a feasible way to deal with these issues?
Thanks in advance!
no hints on the override problems for the elements?
Like mentioned in this thread: maya 2018.1 switching render layers - Issues - Chaos Forum
It seems to be related to Update 1 and the problem was not there without the update. We’ll look into this.
