New Renders
Bedroom Render updated 27th november
Re: New Renders
Perfect! The only thing are the pillows, they look little plastic…look.
Congratulation is really photorealistic.
Zooropa
Re: New Renders
looks nice.
but need to ask something: is there a problem with the beds leg? it is too tappered, isnt it?.
i can guess the geometry of the room and there is no problem with this render but at first look i thought there is a second sun in the seceene and confused you may change the direction of the sun or camera a little bit to give a better understandfing of the room and to prevent any confusions.
these are little things no big deal. i like it anyway.
Re: New Renders
Hi and thanks for your comments,
Zooropa, yes I take your point with regards to the pillows taking on a plastic appearance and I will try to amend this.
Blastered, again I take your point with regards to the bed legs and will give them a squarer section.
You are right about the lights, I had 2 but have since removed 1, as you say it causes confusion in the room.
The light coming in over picture has now been removed.
Thanks again.
MarkO
Re: New Renders
Bedroom 2
Re: New Renders
Wow Wow Wow.! Really congratulations!!! Check the Alumium at Bed! looks a bit shiny…so less realistic.
Your job is really grat.
Bye
Zooropa
Re: New Renders
hi! me again.
curtain is awesome both material and model. is it rhino or smth else?
a suggestion refrain to use 100% black for your diffuse colour. RGB 20,20,20 should be the lowest value for black.
and a question what is that black area seen through the window?
lastly this camera angle seem to be defining the wardrobe not the room if your goal was that i have nothing to say. if not and you are in trouble with finding a good angle you can change the lens lenght to max 25(human eye is 35) that may give you more space but distorts objects.
but overall this is a good render.
Re: New Renders
Very Nice, all around. “tough crowd”.
Re: New Renders
Kitchen 1
Kitchen 2 updated 29th August
Re: New Renders
Sliding Robe
View 2
Re: New Renders
Room Ver 2
Re: New Renders
The sliding robe it’s a breath taking! What a beautiful achievement! You have my respect Sir!
Re: New Renders
“a suggestion refrain to use 100% black for your diffuse colour. RGB 20,20,20 should be the lowest value for black”
Hi Blastered and thanks for your past comments which I have now found some time to answer my apologies.
With regards to the black, this is always been a problem, not with V-Ray but with me, I still think it is a monitor calibration thing because on my monitor the black you mention looks ok on mine, this is also the case with what you see out the window its not black at all on my monitor but dark grey cloud. The doors are a wood grain as well (wenge)which is a dark brown and black stripe.
Curtain is a max model and material was done with V-Ray for rhino.
“lastly this camera angle seem to be defining the wardrobe not the room if your goal was that i have nothing to say.”
Yes the goal is to define the sliding robe.
“but overall this is a good render.”
Many thanks
Zooropa: thanks for your coments
“Check the Alumium at Bed! looks a bit shiny…so less realistic.”
working on it, thanks
ratrace: again thanks for the coments,
“tough crowd”.
No, everyone is pretty cool on this forum.
My quote for the day “no one gives bad comments only sound criticism”.
Stefan: you are to kind sir, and your comments are greatly appreciated, but have a look at some of the master’s work within this and the main gallery and you will see some real talented people.
Re: New Renders
Renders are so beautiful that i will download and archive them with your name if you let. :o
Re: New Renders
Great work you got here!
Truly amazing, sliding robe is my favorite too.
Can you share your setup for carpet, it looks fantastic!
Re: New Renders
Hi Selant, thank you for your comments and yes feel free to download.
Hi SreckoM again thank you for your comments, with regards to the rug, I would like to say it was challenging and difficult but the truth is it was easy. It is made from a patch of grass and scaled to a good size that resembles that of a rug then it is copied and pasted several times and the whole thing is then linked together and finally change the colour to any thing you want.
Regards
Mark
Re: New Renders
room 3
Room 3B
1)Turned off ceiling lights, removed rectangular light that was at the left hand side of the room to help highlight sliding robes.
2)Only light source is hdri and using the physical camera to make light adjustments.
3)Removed a lot of the reflection from the floor.
I think I need more light back in the room
New window opening on opposite side of room
Re: New Renders
Nice one! May I ask what’s the settings of your ‘sand-blasted’ glass? I found a way do do it, but yours it’s better. Thanks!
Re: New Renders
Bedroom set
Re: New Renders
Living room
