New Scene Conterter Tx file conversion.
Ihm Trying the new scene converter. A thing I allways did was converting every used texture into tx and load those.
Now I’ve got a converter that’s folder based and doesen’t seem to reassign textures. Do I now have to go through every bitmap loader by hand and change it so the TX file is used? Kinda feels a little less convinient as before.
I sure hope not. I have also been using the new convertor, and I assume it reassigned the path.
You are likely using the tool to mass-convert textures to .TX format.
The default converter has multiple tabs in this release, but the default one, named “Scene Converter”,
has this section which takes care of it automatically.
We should add a proper description to the other tools though, that is something we should have thought of, and perhaps call the main rollout tab “V-Ray Scene Toolset”, or something along the lines.
Many thanks for pointing it out!​
Works, thanks!
