New series of Corona renders
Having fun with corona …
you Looks like you are good at lighting but your scenes require more work with details.
You must have used an old DSLR for this - so much noise. :smiley:
These are just evermotion models thrown into an empty room… so naturally there’s not muche detail. I was just testing corona, not an actual work.
DSLR? No way, these were taken with an old film camera. :smiley:
The renders were clean, noise was added in post. So it’s not noisona, but that’s a good idea for a new renderer: starts with a clean image and the more time you let it render the more noisy it gets. Great idea!
I don’t think it would be exactly the same. If you don’t let it render for a long time pixel infromation isn’t there. If you add noise to a complete image you’re just covering up a little the information and richness of tones alreday in there.
I’m not completly sure if what I’m saying is correct but I’m going to test it: “low render time” noise vs “long render time + post” noise.
Would it be possible to make a renderer that instead of starting from black and adding light to it, would start from white and subtract points that are dark? :smiley:
how u make a light here?? looking realistic, except so strong noise
Lighting is HDRI only.
