[New Tool] C4Designer V0.4.1 (Substance like shader creation)
Hi Guys,
I want to present you something that I’ve been working on for a while.
Creating, especially layering shaders isn’t always easy and can be quite confusing,
so I started my own plugin to emulate Substance Designer’s workflow.
Now you can easily drag all your noises, pattern etc. into the xpresso pool, connect it to the py script and that to the channel you want to map.
You can blend, normalize, change curves/HSV, drag-transform and much more with the provided nodes. It also features an interactive 2D preview of the selected node and it works very well with IR.
Notes & how-to are provided in the scene file
Give it a try and tell me what you think!
C4Designer_v0.4.1.c4d (135 KB)
Works perfectly! :wink:
Hey, thanks!
It sped up my WF a lot. It took me a minute to make the dunes with the tool. Just added a fresnel + color. done!
Wow ! Thank you, it looks promising.
The version is a bit out-dated. Can’t guarantee that it works properly now…
Eddoron, do you have some getting started tips? You open the scene, and then…? :smiley:
Believe :wink:
… your eyes, your mind, your heart and utmost in yourself
imagine…
