New Vray serial
So do we just use the same serial number for the new version of Vray that we used for v1.5? Or will we be sent a new serial code?
Re: New Vray serial
You should use the same SN.
Re: New Vray serial
ok, thanks for letting me know.
Re: New Vray serial
have you been able to download the new release?
i still can’t seem to even get the new release and there has been no formal explanation.
i heard rumors about snow in baltimore which is understandable, but isn’t this 2010? can’t we at least get an explanation or email?
Re: New Vray serial
We worked from home, and last we checked all of the download links were working. I just hopped on to see if anyone was having issues. Do you guys have a problem when you try to download from here?:
http://software.asgvis.com/index.php?option=com_content&view=article&id=182&Itemid=480
We will look in to the issue with the links in the release email, and after the order tomorrow. We apologize for any inconveniences this may have caused. The reason nobody was informed of a delay, is we were under the impression it was all functioning properly.
Re: New Vray serial
Devin,
Thanks again for the clarification and working links.
Very excited to give it a whirl.
Your guys’ hard work is much appreciated~
Re: New Vray serial
Hi Do we need to uninstall the old one before we install the new version or does it automatically update it.
Thanks in advance.
Re: New Vray serial
You have to uninstall the old version first.
BEst
