new website
After ten years it was timne for a new website.
www.ubikmh.nl
Comments are welcome.
Marc
I do like it, its clean and simple! Although one thing is bugging me, when I press an image it turns grey and it freezes, I belive it should reveal the image in bigger resolution?
Very good and clean work overall! It rings a bell into my conscience, I must do the same to my old undated website… :slight_smile:
Allways a pleasure to see your work Marc
Cheers
For me the button selections on the first page are quite fiddly and you have to be pretty accurate to select them. I am at a resolution of 2560x1600 so maybe its my resolution.
Yes, that’s a quite heavy resolution. But I agree that the text is rather small. I’m not sure if I’ll change it though. I changed some other things. The loading should be much better now. I can’t have my friend Goncalo’s computer freeze now, can I?
If you guys have suggestions, please write them here. I’m allways looking for improvements.
Marc
It still freezes here!
Cheers
This is what happens when I press an image:
However first time I’ve try it it worked fine…
For some reason the shadow box doesn’t load on your computer. Haven’t had that complaint before.
Can you scroll the smaller images?
Do you have the problem with all the sections or just this one?
Marc
I can srcoll the small images by pointing the mouse over the arrow only. The greyish freeze on pressing the images happens on all sections and on both computers I have here running Windows XP Professional SP3 32bit. By clicking anywhere on the page it returns to normal and I can scrool the images again.
Cheers
