I am thinking to buy a new pc, please give some advise on this specification, should I buy this pc?
Hi @jackieteh
Upgrading from Threadripper 1950X to Ryzen 9950X is a big upgrade, you will notice a difference in pretty much everything.
Your build looks ok, although if you wanna safe some money you could go for the older Ryzen 9 7950X. You will get the exact same performance and you will safe 300 Euros on the CPU and motherboard.
Otherwise make sure your case is big enough to house your 4090, and that your CPU cooler supports the new Ryzen 9950X
Best,
Muhammed
Thank you very much for your guide and help.
@jackieteh
Last year I put together a system with slightly lower specs than yours.
It has been 100% reliable.
Make sure you get the EXPO AMD memory kit. Some AMD users have had trouble with Intel XMP.
Use the cables that come with your power supply.
Good luck & enjoy your new system,
Glenn
Windows 11 Pro
Ryzen 9 7900X
MSI MPG X670E CARBON
Noctua NH d15s
Corsair VENGEANCE® 64GB (2x32GB) DDR5 DRAM 6000MT/s C40 AMD EXPO Model CMK64GX5M2B6000Z40
(2x) Samsung 990 PRO 1tb
ASUS TUF Gaming RTX 4070 Ti OC
Seasonic VERTEX GX-1000
UPS CP1500AVRLCD3 1500VA/900W
Well said, it is a mistake many people make
Until they realize V-Ray is crashing nonestop
Best,
Muhammed
May I know what is AMD EXPO? is it only needed if I want to do overclock?
@jackieteh
yes for sure if you overclock the ddr5 ram, probably makes a difference even in stock speeds but I’m not sure as I always use that feature for either AMD or Intel based systems.
AMD Extended Profiles for Overclocking represents a new type of memory profiles that allow you to quickly and easily set the maximum speed for your memory. With just one click, you can instantly set the frequency, timings, and voltages used by your memory without having to make any manual changes in your computer’s UEFI BIOS.
https://www.digitalcitizen.life/amd-expo/
If you don’t enable it your memory will run at 4800.
depending on your budget, you might want to look into slightly faster DDR5 speeds. Ryzen 9 9950 or 9950X can handle faster, which of course is more expensive.
Perhaps @Muhammed_Hamed can add to the DDR5 speed vs. Vray performance conversation regarding CPU or GPU
And of course, if you are comfortable going into BIOS to make the changes.
MSI bios is very simple to use, the EXPO button is on the main page, as on or off, sometimes there are a couple options.
In the BIOS is where you will set your case & CPU cooler fan speeds/curves.
Glenn
@jackieteh
You can find a lot of great information about putting a pc together on YouTube, Reddit, and PcPartpicker (great site to make sure all your components will work together for size and power), and of course in the Vray forum!
Quick overview, when I build a system, I start with software I want to run and any I may run in the near future.
Then go to those sites to review system requirements.
With the list of components you noted, looks like you have already done that.
If you haven’t put a computer together recently, go to YouTube there are a lot of videos on general building, and you can also search on the components you are using for more specific instructions (AMD chips insert into the motherboard differently than Intel)
Then another video on loading the operating system, drivers, software, etc.
Make good notes on the SEQUENCE of assembly steps, watch the videos multiple times, then when you actually do it, it will be familiar.
Glenn
Thank you for your guide. But I have doubt on should I install window 10 or window 11? sound like window 11 have some problem…
Windows 10 loses support officially in 2025, you will need to move to Windows 11 eventually. You might as well move now
About Memory frequency, if you have all memory slots occupied you might have issues getting your memory to run at the rated overclock. Best is not to spend money on expensive/fast memory to only need to run it at stock for stability
Best,
Muhammed
Sorry about not being clear
You do need Memory that is AMD friendly for sure, it will have the AMD Expo labeling. This is needed for AMD workstations, as if you run other memory designed for Intel it will be unstable
That being said, my advice is go for 128 GB memory, you already buying a lot of expensive parts and you need your machine to be future proof. 5600 or 6000 are maximum speeds for the memory you buy(and it needs to be AMD friendly)
You will go to BIOS to try and run it at the rated overclock above 4800, if that doesn’t work out for you(most people have the same issue), it is not too bad to leave your memory at stock speeds
Let us know how it goes
Best,
Muhammed
I will give a try with my 64GB RAM, what is maximum speed for 128GB RAM?
lowest you could find, anything below 6000
Best,
Muhammed
I think i misunderstanding, the 64GB RAM and 128GB RAM have the same maximum of 6000?
There is nothing really as maximum..
What I’m trying to say is to not to spend money on high-frequency memory which could be a waste(if you find 5800 memory and 7000 memory, pick the 5800). There are some low-latency high speed kits that are expensive, they could work fine for gaming, it will be hard to make them stable for rendering if all 4 memory slots are occupied
Best,
Muhammed
5800 and 7000 is it a figure of the RAM speed? or do you mean if I have found 2 memory 1 is 5800MHZ the others 1 is 7000MHZ, choose the 5800MHZ one, is it correct?
In my quotation, I have 2x32GB, which mean it is occupied 2 slot only, which mean it will be more stable?
Is this mean no need to buy AMD EXPO RAM if I am not doing overclock? because i don’t like to do overclock
Yeah it should
It is needed even if you don’t overclock
