I’m running version 2.8.0-preview.3+22363 and I’m having lots of problems, I’ve no skyboxes or backgrounds as no matter what I select I get the white background, lights no longer work in models that were perfectly fine previously and it has reverted to the earlier problem of rendering scenes from a great distance away rather than the viewport window. Can someone tell me what the last stable version for Sketchup was and how I can revert back to it please? I’ve never had to undo an update before so I’m not sure what I’m doing.
Thank you.
@Grizzler , it sounds like your currently in orthogonal mode. Please go the Visual Settings → General tab → Projection → set it to Perspective again or Two-Point, as the Orthogonal mode makes the background white by default due to technical reasons, and it also changes the camera distance (field of view) itself. Does this also help with your lights, or do you still then experience issue?
Hello Demian. I’ve reverted back to 2.7. I may possibly have been in Orthogonal projection, but I didn’t select that mode so it could only have happened if that is the default setting upon installation, as I only ever use Perspective projection.
It shouldn’t be the default setting, you can gladly let us know if that is the case on your machine though if you perhaps get the chance to try the preview once more soon.
