Next: Any mode in VRayMultiSubTex to be used instead of RailClone Color?
Hi Guys
Since Next doesnt support RailClone Color, as an alternative how may I go about using VRayMultiSubTex instead on RailClone Objects?
Even if I have to stick an edit poly on top of a RailClone object, that is fine. I just want to render with GPU without the RailClone Color incompatibility issues
I think you have to uncheck the instance option (forgot the proper naming) in railclone. Then vray can read the material IDs…
