Will this boost rendering when path tracing complex GI situations?
It already is
Can you explain what is it ?
It’s just fancy name for shadow rays
really?
I though that it is some nice ultra pathtracing on steroids in VCM
lol… Anyways, seems to be similar to bi-dir speedwise…
Ah, you mean you use it in VCM
No, that just sets the VCM renderer into mode equivalent to using PT+PT with max sample intensity 0 and PT samples and light multiplier = 1.
You can see the effect of turning next event estimation on/off by using PT+PT and switching direct light mode between MIS and BSDF only
Keymaster, Bdir code is still broken in latest builds:
bidirrenderer.ccp(261)
yes, it will be probably eventually removed. Use VCM in bidir mode instead
Ok it works with VCM as renderer, thanks.
By the way… What is the difference between using VCM in Bi-Dir mode and standard Bi-Dir?
That VCM in bidir mode does not crash ![]()
lol
I was more wondering why you chose to dump standard bidir and use VCM but okay, I understand if you don’t want to tell ![]()
trolling is an art ;).
but seriously, VCM is slightly slower, because it is harder to parallelize right. But since VCM is in a way a combination of ALL other algorithms used for unbiased rendering (except for metropolis ones), it is very easy to modify it to get these algorithms (bidir, progressive photon mapping, path tracing, light tracing). And since bidir is very complicated and demanding, it does not make sense to maintain a separate implementation. I’ll just have to make the multithreading more efficient.
