next update 2 - IPR crashing max
hello,
installed update 2, opened a scene that worked fine with update 1 and now with update 2 when I click the stop button while IPR rendering, max(2020) crashes.
I found some other scenes that crash exactly the same way. Normal rendering works fine.
See image attached for the error I get.
Could you share some of those crashing scenes ?
Yavor
yes, what’s the best way to do this?
send a mail to
support@chaosgroup.com
and they’ll assist you, including finding the best way to move the (possibly big) package efficiently. :smile:
ok, I found the problem.
If a corona material is present in the scene, IPR crashes max.
Just went back to update 1.1 - no problem at all.
The following steps crash max:
create a box > switch to corona and apply corona material > switch back to vray > start IPR (from toolbar)
Reproduced. It will be fixed, thanks!
Same here!
Same here!
We will have a hotfix in a few days that fixes this issue; thanks for reporting it!
