It’s killing me! I have tried for two days to render this out. It was rendering fine until I upgraded to 5.1.
[2021/Feb/28|12:02:25] Calling endFrame().
[2021/Feb/28|12:02:25] Calling endFrame() in the main thread.
[2021/Feb/28|12:02:25] Entering endFrame().
[2021/Feb/28|12:02:25] Broadcasting NOTIFY_POST_RENDERFRAME.
[2021/Feb/28|12:02:25] Applying render effects.
[2021/Feb/28|12:02:26] error: UNHANDLED EXCEPTION: Applying render effects.
Last marker is at D:\cgrepo\vray\vray\src\vrayrenderer.cpp, line 5566: Preparing global light manager
If you have a scene file I would be happy to look at it too. So far I’m not aware of any V-Ray 5.1 specific issues/changes that would effect psd-manager 5 and would require a change on the psd-manager side.
Do you recall if the PSD file was saved successfully when the error occurred (or if not could you save it later via “Save Now”)?
Empty file (0 bytes) / partially saved file / no file saved / previous file not overwritten / don’t know?
Did you try saving using psd-manager 5’s “Save Now” button after the error occurred?
