Hi All,
Are the nightly builds accessible for Vray houdini anywhere or do i need to be invited somehow?
Cheers,
Rory.
Hi All,
Cheers,
Rory.
https://nightlies.chaosgroup.com/ - log in with your username/password. If you don’t see any Houdini builds, please message support@chaosgroup.com - they can provide you with access.
Cheers!
Write to support@chaosgroup.com.
Is it too early to ask if Houdini 18 will be supported soon ? Thanks
stevejjd, build is already available at the nightlies.
Wow thats quick - thanks
Hi Andrei,
Last version I’m seeing in the “vray4houdini/stable/4.12/20191202” nightlies-folder is : vray_adv_41203_houdini17.5.293_09fbddd_5928_windows.zip
Is that the one to be used with H18?
This is so odd because I can’t see any builds for houdini 18. I contacted the support team. No answer yet. I have access to nightlies but not for houdini 18. I really want to see if Vray has a render deligate for viewport rendering, and if I can use the new LOPs system. (Karma, USD scene builder). ![]()
SAme here, i don’t see H18 nighly
Hey, guys,
USD support will take a while - naturally the plan is to support USD/LOPs, and we have something in the works already. As you can imagine, it’s a huge task for the teams across all integrations. We’ll let you guys know as soon as we have something for you to play with.
As to the H18 builds not showing up for you - I’ll check with the licensing team.
All the best!
You guys need to email support and ask for access to the 18.x builds - like @bdancer says, it’s a different folder, not visible with the regular nightly access. I did drop an email to the support and got response/access pretty fast.
Already asked, I received this answer : You have access to all available nighties for V-Ray for Houdini. but no. i’ve only access to stable.
Same happened to me, didn’t see the 18.x folder. Gave them the link to a 18.x nightly build posted by @bdancer , worked second time.
See the post/link here: Color Correction node connected to gloss - Issues - Chaos Forum
I wrote 2 others emails yersterday with more informations, link from @bdancer like sugested by @miro.digital . DOn’t receive answer from support. Today i check my nightly list. only stables.
Same here.
We’ll do a double check on our side just in case. Meanwhile, would you please log-out from the https://nightlies.chaosgroup.com/ website and log-in again.
It’s a final step that needs to be executed, otherwise the browser keeps the cache information from previous sessions and does not display the changes.
If you still can’t see the builds after log-out and then log-in, or you don’t have an answer from the Support Team, please drop me a line at svetlozar.draganov@chaosgroup.com and send me the Case ID (Ticket Number) so I could check what’s going on.
Solved for me with Support team, thanks you guys ![]()
How to use Vray with Solaris ?
You can’t. USD is not supported.
USD renderer API has nothing in common with ROP and completely new implementation is required.
ARe you working on it ? because it’s really powerfull to work in Lops now. Redshift is on it, Renderman too . you can beat them and karma if you support USD/hydra.
