> ARe you working on it ?
Yes.
Yes.
that’s really exiting
thanks you !! when you begin to understand Solaris, you never want to setup again your scene in other way ![]()
I just noticed I had this path: C:\Program Files\Chaos Group\V-Ray\Houdini 18..0.287 - Are the two dots supposed to be there? ![]()
The details of the error are these:
Traceback (most recent call last):
File “object_VRayNodeLightAmbient”, line 1, in <module>
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\toolutils.py”, line 1382, in new_func
return function(*args, **kwargs)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\objecttoolutils.py”, line 491, in genericTool
exact_node_type = exact_node_type)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\toolutils.py”, line 1503, in genericTool
exact_node_type)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\toolutils.py”, line 1362, in createNodeInContainer
exact_type_name = exact_node_type)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\houpythonportion\ui.py”, line 851, in decorator
return func(*args, **kwargs)
File “C:/PROGRA~1/SIDEEF~1/HOUDIN~1.287/houdini/python2.7libs\hou.py”, line 9251, in createNode
return _hou.Node_createNode(*args, **kwargs)
OperationFailed: The attempted operation failed.
Invalid node type name
Thanks, again!
No, they are not.
Just to confirm - removing the dot is fixing your issue, right?
I’ve just installed it locally.
No double dot is generated for me. Package file is also correct and plugin is loaded.
Please, double check your installation.
I tried the manual installation (.env file), like I used to before, but I get the same error.
Hello @Ambrozie , are you sure the paths in the installation setup are correct. By default, they might not handle your Houdini directory correct.
My bad, I was using the wrong installer from the “V-ray for Houdini stable” folder. I requested access to the nightly builds. Thanks
Hello, I am new to vray and I am here because I have to install Houdini 21 with compatible vray7 version. One of FX artist asked me to login here and ask if there is a build I could get? appreciate it
Dear @sinagra , hello.
Support of Houdini 21 is under development. The builds are not yet officially released.
Thank you for your patience and understanding.
Dear all,
We are happy to inform you that V-Ray version for Houdini 21 has been released - V-Ray 7 Update 2.
Find it here.
Best,
TS
