we got problems by using “export locally/render job” . in the vraynode ->ExportMode: export (using export&render after submitting, it switched back to only “export”); Exportfilepath: a shared folder on storage.
in the vray deadline node: export locally/render job
The job is submitted to deadline, but there the slave say:
“Reading scene file “C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Sepp\jobsData\5e985a01149e42230c0af1bf\thread0_tempEnJoT0\X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene”
2020-04-16 15:15:04: 0: STDOUT: [2020/Apr/16|15:15:03] [58 MB] error: Error in file “C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Sepp\jobsData\5e985a01149e42230c0af1bf\thread0_tempEnJoT0\X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene”, line 0: No file “C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Sepp\jobsData\5e985a01149e42230c0af1bf\thread0_tempEnJoT0\X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene” exists”
on the slave the local temp folder exists, but no vrscene file in it.
submitting manually , the exported vrscene in the deadline gui submission, works.
any suggestions?
Any luck to see the full log?
sure…
Log
2020-04-20 17:21:35: 0: Loading Job’s Plugin timeout is Disabled
2020-04-20 17:21:37: 0: Executing plugin command of type ‘Sync Files for Job’
2020-04-20 17:21:38: 0: All job files are already synchronized
2020-04-20 17:21:38: 0: Plugin Vray was already synchronized.
2020-04-20 17:21:38: 0: Done executing plugin command of type ‘Sync Files for Job’
2020-04-20 17:21:38: 0: Executing plugin command of type ‘Initialize Plugin’
2020-04-20 17:21:38: 0: INFO: Executing plugin script ‘C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Otto\plugins\5e9dbd6d7ce0e40774fa2416\Vray.py’
2020-04-20 17:21:38: 0: INFO: About: V-Ray Standalone Plugin for Deadline
2020-04-20 17:21:38: 0: INFO: Render Job As User disabled, running as current user ‘maya’
2020-04-20 17:21:38: 0: INFO: The job’s environment will be merged with the current environment before rendering
2020-04-20 17:21:38: 0: Done executing plugin command of type ‘Initialize Plugin’
2020-04-20 17:21:38: 0: Start Job timeout is disabled.
2020-04-20 17:21:38: 0: Task timeout is disabled.
2020-04-20 17:21:38: 0: Loaded job: X666_Tryouts_sha_TEST_TEST_A_v001_tok | /obj/Rop_OUT/Main | render | frame:0 (5e9dbd6d7ce0e40774fa2416)
2020-04-20 17:21:38: 0: Skipping Y: because it is already mapped
2020-04-20 17:21:38: 0: Executing plugin command of type ‘Start Job’
2020-04-20 17:21:38: 0: DEBUG: S3BackedCache Client is not installed.
2020-04-20 17:21:38: 0: INFO: Executing global asset transfer preload script ‘C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Otto\plugins\5e9dbd6d7ce0e40774fa2416\GlobalAssetTransferPreLoad.py’
2020-04-20 17:21:38: 0: INFO: Looking for AWS Portal File Transfer…
2020-04-20 17:21:38: 0: INFO: Looking for File Transfer controller in C:/Program Files/Thinkbox/S3BackedCache/bin/task.py…
2020-04-20 17:21:38: 0: INFO: Could not find AWS Portal File Transfer.
2020-04-20 17:21:38: 0: INFO: AWS Portal File Transfer is not installed on the system.
2020-04-20 17:21:38: 0: Done executing plugin command of type ‘Start Job’
2020-04-20 17:21:38: 0: Plugin rendering frame(s): 0
2020-04-20 17:21:39: 0: Executing plugin command of type ‘Render Task’
2020-04-20 17:21:39: 0: INFO: Starting V-Ray Task
2020-04-20 17:21:39: 0: INFO: Performing path mapping on vrscene file
2020-04-20 17:21:39: 0: INFO: The include file Y:\Projects\X666_Tryouts\02_WORK\HOUDINI\Z_Temp\A_SceneDescriptions\vrscene\HOUDINI\X666_Tryouts_sha_TEST_TEST_A_v001_tok\Director\X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene does not exist.
2020-04-20 17:21:39: 0: INFO: Stdout Redirection Enabled: True
2020-04-20 17:21:39: 0: INFO: Stdout Handling Enabled: True
2020-04-20 17:21:39: 0: INFO: Popup Handling Enabled: False
2020-04-20 17:21:39: 0: INFO: Using Process Tree: True
2020-04-20 17:21:39: 0: INFO: Hiding DOS Window: True
2020-04-20 17:21:39: 0: INFO: Creating New Console: False
2020-04-20 17:21:39: 0: INFO: Running as user: maya
2020-04-20 17:21:39: 0: INFO: Executable: “C:\Program Files\Chaos Group\V-Ray\Standalone for x64\bin\vray.exe”
2020-04-20 17:21:39: 0: INFO: Argument: -scenefile=“C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Otto\jobsData\5e9dbd6d7ce0e40774fa2416\thread0_tempKMTeX0\X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene” -interactive=0 -display=0 -rtEngine=0 -frames=0 -imgFile=“Y:\Projects\X666_Tryouts\02_WORK\HOUDINI\D_Output\exr\TEST\TEST_A\Main\Director\v001\X666_Tryouts_TEST_TEST_A_v001_tok_Main_slCG.<frame04>.exr” -numThreads=0
2020-04-20 17:21:39: 0: INFO: Full Command: “C:\Program Files\Chaos Group\V-Ray\Standalone for x64\bin\vray.exe” -scenefile=“C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Otto\jobsData\5e9dbd6d7ce0e40774fa2416\thread0_tempKMTeX0\X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene” -interactive=0 -display=0 -rtEngine=0 -frames=0 -imgFile=“Y:\Projects\X666_Tryouts\02_WORK\HOUDINI\D_Output\exr\TEST\TEST_A\Main\Director\v001\X666_Tryouts_TEST_TEST_A_v001_tok_Main_slCG.<frame04>.exr” -numThreads=0
2020-04-20 17:21:39: 0: INFO: Startup Directory: “C:\Program Files\Chaos Group\V-Ray\Standalone for x64\bin”
2020-04-20 17:21:39: 0: INFO: Process Priority: BelowNormal
2020-04-20 17:21:39: 0: INFO: Process Affinity: default
2020-04-20 17:21:39: 0: INFO: Process is now running
2020-04-20 17:21:39: 0: STDOUT: [2020/Apr/20|17:21:39] [10 MB] warning: The parameter ‘interactive’ has been removed and so it has been ignored!
2020-04-20 17:21:39: 0: STDOUT: [2020/Apr/20|17:21:39] [10 MB] Reading configuration from “C:\Program Files\Chaos Group\V-Ray\Standalone for x64\bin\/vrayconfig.xml”
2020-04-20 17:21:39: 0: STDOUT: [2020/Apr/20|17:21:39] [10 MB] ===============================================
2020-04-20 17:21:39: 0: STDOUT: [2020/Apr/20|17:21:39] [10 MB] V-Ray Standalone, version Next Standalone, update 2.1 for x64
2020-04-20 17:21:39: 0: STDOUT: [2020/Apr/20|17:21:39] [10 MB] Copyright (C) 2000-2019 Chaos Group Ltd. All rights reserved.
2020-04-20 17:21:39: 0: STDOUT: [2020/Apr/20|17:21:39] [10 MB] Use -credits option for additional third-party copyright notices.
2020-04-20 17:21:39: 0: STDOUT: [2020/Apr/20|17:21:39] [10 MB] Build 4b1eea09 from Aug 21 2019, 13:45:58
2020-04-20 17:21:39: 0: STDOUT: [2020/Apr/20|17:21:39] [10 MB] Compiled with Microsoft Visual C++ compiler, version 19.12
2020-04-20 17:21:39: 0: STDOUT: [2020/Apr/20|17:21:39] [10 MB] Operating system is Microsoft™ Windows™, version 6.2,
2020-04-20 17:21:39: 0: STDOUT: [2020/Apr/20|17:21:39] [10 MB] V-Ray core version is 4.20.01
2020-04-20 17:21:39: 0: STDOUT: [2020/Apr/20|17:21:39] [15 MB] Loading plugins from “C:\Program Files\Chaos Group\V-Ray\Standalone for x64\bin/plugins/vray_*.dll”
2020-04-20 17:21:40: 0: STDOUT: [2020/Apr/20|17:21:40] [58 MB] 90 plugin(s) loaded successfully
2020-04-20 17:21:40: 0: STDOUT: [2020/Apr/20|17:21:40] [58 MB] Finished loading plugins.
2020-04-20 17:21:40: 0: STDOUT: [2020/Apr/20|17:21:40] [58 MB] Reading scene file “C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Otto\jobsData\5e9dbd6d7ce0e40774fa2416\thread0_tempKMTeX0\X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene”
2020-04-20 17:21:40: 0: STDOUT: [2020/Apr/20|17:21:40] [58 MB] error: Error in file “C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Otto\jobsData\5e9dbd6d7ce0e40774fa2416\thread0_tempKMTeX0\X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene”, line 0: No file “C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Otto\jobsData\5e9dbd6d7ce0e40774fa2416\thread0_tempKMTeX0\X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene” exists
2020-04-20 17:21:40: 0: STDOUT: [2020/Apr/20|17:21:40] [30 MB] Closing log - 1 error(s), 1 warning(s).
2020-04-20 17:21:40: 0: STDOUT: [2020/Apr/20|17:21:40] [2020/Apr/20|17:21:40] Max memory usage: 58 MB
2020-04-20 17:21:40: 0: STDOUT: [2020/Apr/20|17:21:40] Issues Report:
2020-04-20 17:21:40: 0: STDOUT: [2020/Apr/20|17:21:40] Warnings:
2020-04-20 17:21:40: 0: STDOUT: [2020/Apr/20|17:21:40] The parameter ‘interactive’ has been removed and so it has been ignored!
2020-04-20 17:21:40: 0: STDOUT: [2020/Apr/20|17:21:40] Errors:
2020-04-20 17:21:40: 0: STDOUT: [2020/Apr/20|17:21:40] Error in file “C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Otto\jobsData\5e9dbd6d7ce0e40774fa2416\thread0_tempKMTeX0\X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene”, line 0: No file “C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Otto\jobsData\5e9dbd6d7ce0e40774fa2416\thread0_tempKMTeX0\X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene” exists
2020-04-20 17:21:40: 0: Done executing plugin command of type ‘Render Task’
suedlich_t, and the export log? Where the vrscene was exported? The issue is obviously that file is not found - but was it exported? And where?
ah , oh, i noticed the line:
“2020-04-20 17:21:39: 0: INFO: The include file Y:\Projects\X666_Tryouts\02_WORK\HOUDINI\Z_Temp\A_ SceneDescriptions\vrscene\HOUDINI\X666_Tryouts_sha _TEST_TEST_A_v001_tok\Director\X666_Tryouts_TEST_T EST_A_v001_tok_Main.0000.vrscene does not exist.” → the output path in houdini is set to " Y:\Projects\X666_Tryouts\02_WORK\HOUDINI\Z_Temp\A_ SceneDescriptions\vrscene\HOUDINI\X666_Tryouts_sha _TEST_TEST_A_v001_tok\Main ! we didnt know why there is “Director” in the path ?
export log:
VFH * Build number:6879 hash:78bcfe2 from 14 Apr 2020 06:11
VFH * V-Ray 4.30.03
VFH * V-Ray Deadline: Grabbing submitter info…
VFH *
VFH * Deadline version: v10.1.1.3 Release (a53d3f404)
VFH * V-Ray Deadline ROP: “/obj/Rop_OUT/vrayDeadline” [622b599]
VFH * ROP: “/obj/Rop_OUT/Main”
VFH V-Ray: Loading plugins from “Y:\SL\SL_Programs\vray\vray_adv_43003_houdini18.0.391_78bcfe2_6879\appsdk\bin/plugins/vray_*.dll”
VFH V-Ray: 91 plugin(s) loaded successfully
VFH V-Ray: Finished loading plugins.
VFH * Processing scene for frame 0.000…
VFH * Scene processing time: 0h 0m 0.2s
VFH * Starting export to “Y:/Projects/X666_Tryouts/02_WORK/HOUDINI/Z_Temp/A_SceneDescriptions/vrscene/HOUDINI/X666_Tryouts_sha_TEST_TEST_A_v001_tok/Main/X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene”…
Exception TypeError: “‘bool’ object is not callable” in <bound method ExportModeSetter.__del__ of <vfh.vfh_deadline.ExportModeSetter instance at 0x000000008A055D08>> ignored
VFH V-Ray: File “Y:/Projects/X666_Tryouts/02_WORK/HOUDINI/Z_Temp/A_SceneDescriptions/vrscene/HOUDINI/X666_Tryouts_sha_TEST_TEST_A_v001_tok/Main/X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene” exported with 134 plugins
VFH * [/obj/Rop_OUT/Main] Render job “X666_Tryouts_sha_TEST_TEST_A_v001_tok | /obj/Rop_OUT/Main | render | frame:0” ID: 5e9dbd6d7ce0e40774fa2416
VFH * Submission done.
Have you used opname?
Not sure where there is a space in “vrscen e” “Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscen e”… could u pls check the hip file?
what u mean with “opname” ?
our exportfilepath entry in houdini: $JOB/Z_Temp/A_SceneDescriptions/vrscene/HOUDINI/$HIPNAME/$OS/${slPROJECT}_${slSEQUENCE}_${slSHOT}_${slVARIATION}_${slVERSION}_${slUSER}_${ACTIVETAKE}.$F4.vrscene
`opname()` or $OS.
> X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscen e"
So is there a space “vrscen e” or it’s because of some forum formatting?
What are the directory contents?
oh yes, seems a forum formatting thing.
in the directory is the correct vrscene file : “X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscene” (<- forum formating bug)
This is export path:
VFH * Starting export to “Y:/Projects/X666_Tryouts/02_WORK/HOUDINI/Z_Temp/A_SceneDescriptions/vrscene/HOUDINI/X666_Tryouts_sha_TEST_TEST_A_v001_tok/Main/X666_Tryouts_TEST_TEST_A_v001_tok_Main.0000.vrscen e”…
Here is load error:
So, have you tried removing $OS?
without $OS it is fine.
export path then:
VFH * Starting export to "Y:/Projects/X666_Tryouts/02_WORK/HOUDINI/Z_Temp/A_SceneDescriptions/vrscene/HOUDINI/X666_Tryouts_sha_TEST_TEST_A_v005_tok/X666_Tryouts_TEST_TEST_A_v005_tok_Main.0000.vrscen e
the submite adds “Main\Director” to the image path
2020-04-21 11:12:17: 0: INFO: Executable: “C:\Program Files\Chaos Group\V-Ray\Standalone for x64\bin\vray.exe”
2020-04-21 11:12:17: 0: INFO: Argument: -scenefile=“C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Otto\jobsData\5e9eb8ea454841243861daf1\thread0_temp9cPYv0\X666_Tryouts_TEST_TEST_A_v005_tok_Main.0000.vrscene” -interactive=0 -display=0 -rtEngine=0 -frames=0 -imgFile=“Y:\Projects\X666_Tryouts\02_WORK\HOUDINI\D_Output\exr\TEST\TEST_A\Main\Director\v005\X666_Tryouts_TEST_TEST_A_v005_tok_Main_slCG.<frame04>.exr” -numThreads=0
2020-04-21 11:12:17: 0: INFO: Full Command: “C:\Program Files\Chaos Group\V-Ray\Standalone for x64\bin\vray.exe” -scenefile=“C:\Users\maya\AppData\Local\Thinkbox\Deadline10\slave\Otto\jobsData\5e9eb8ea454841243861daf1\thread0_temp9cPYv0\X666_Tryouts_TEST_TEST_A_v005_tok_Main.0000.vrscene” -interactive=0 -display=0 -rtEngine=0 -frames=0 -imgFile=“Y:\Projects\X666_Tryouts\02_WORK\HOUDINI\D_Output\exr\TEST\TEST_A\Main\Director\v005\X666_Tryouts_TEST_TEST_A_v005_tok_Main_slCG.<frame04>.exr” -numThreads=0
this would be okay for now, but where the “Director” come from
“Director” is coming from $OS variable.
$OS is the name of the node this $OS var is used at, I’ll try to figure out why it’s not evaluated correctly (Director is the name of the most top context node “/”).
