No compatible GPU found
Hi, I’ve been trying to use the Vantage free trial and having this issue when trying to run the program, cannot get past this error “No suitable GPU device found! A DXR compatible device is required”. My PC has a Quadro RTX 5000 which as far as I’m aware supports DXR.
Here is a copy of the debug log:
15:53:00.513 === 02/13/2025 ===
15:53:00.513 Chaos Vantage v2.6.2 (build 2990504, hash cb7cd412)
Build date: Nov.26.2024
15:53:02.586 No VR headset available.
15:53:03.120 Window initialized in 2605.5 ms
15:53:03.120 System memory: 62.63 GB
15:53:03.120 Windows version is 10.0.19045.
15:53:03.120 Hardware accelerated scheduling: off
15:53:03.148 Device #0: NVIDIA Quadro RTX 5000, 16170 MB (DevId=0x1EB0, SubSysId=0x129F10DE)
15:53:03.150 Output device: \\.\DISPLAY1, HDR=0, BitsPerColor=8, ColorSpace=0, RedPrimary=(0.640, 0.330), GreenPrimary=(0.300, 0.600), BluePrimary=(0.150, 0.060), WhitePoint=(0.313, 0.329), MinLuminance=0.500, MaxLuminance=270.0, MaxFullFrameLuminance=270.0
15:53:03.150 Output device: \\.\DISPLAY2, HDR=0, BitsPerColor=8, ColorSpace=0, RedPrimary=(0.640, 0.330), GreenPrimary=(0.300, 0.600), BluePrimary=(0.150, 0.060), WhitePoint=(0.313, 0.329), MinLuminance=0.500, MaxLuminance=270.0, MaxFullFrameLuminance=270.0
15:53:03.224 Can’t use device #0 - no INLINE raytracing support (0x0). Skipping.
15:53:03.248 Device #1: Microsoft Basic Render Driver, 0 MB (DevId=0x8C, SubSysId=0x0)
15:53:03.251 NVIDIA driver version 443.36 detected.
15:53:03.251 No suitable GPU device found! A DXR-compatible device is required.
16:05:53.071 Closing GUI…
16:05:53.071 Closing base renderer…
16:05:53.071 Closing window…
This is on my work PC which is tightly controlled by IT so I can’t play around with some of the potential fixes I’ve read, just look for a definitive answer I can take to IT for them to act on. Appreciate any advice or help, thanks.​
Hi, this driver is VERY old. The minimum requirement is now 535+ as you can see on the download page.
… and yes, this GPU is compatible.
Ah thanks, that would explain it! All our updates get pushed out to us but I guess gpu drivers aren’t included, I’ll get onto them to update, thanks again.
i have Nvidia Geforce RTX 3080 MY driver 572.16 update but still Vantage not working ?
This should be fixed in the next patch 2.7.1. Until then I think you can use version 2.6.1 because the issue started in 2.6.2.
