I have problem , i set every material ( od load from already set material ) and there is no displacement
, someone can show me all setting needed to usa displacement ? maybe i forget to set sth
, thx.
Re: No displacement/bump
In sketchup, ‘select’ the surface to be displaced, right click and select ‘bounding edges’, and then select ‘make group’. In other words, the surface and its edges need to be grouped for it to work. If your displacement values are correct it should now displace!
Good Luck
David
thx it works
, but , i made a component like building , how to this set bump ? for example i take one wall , make group and in render ther is no wall , a make a group from component ane no model in render
, only for single surface it works as i see , still sth wrong ?
yep - this happens to me too.
It seems that vray doesn’t like nested groups/components, so (unless anyone can suggest otherwise) you have to explode the components, and only group the faces that you want to displace. (this may be fixed in the upcoming release)
David
Sometimes, even if one material is grouped together to be displaced…displacement doesn’t work. I have a grass texture that I’m displacing where some patches of grass work and some patches that don’t work. When I apply the texture to a surface, I’ve made sure to select all lines as well. I’ve come to the conclusion that displacement is just quirky. You just have to mess with it till it works or just work around it.
