No GI render element ?
I know this has been brought up a few times (when I use search) but I haven’t found any actual answers yet.
So is it currently possible to render out the elements needed to fully composite an image? coming from Vray I would expect some sort of direct light and GI element but I can’t seem to get my head around this currently?
I might just be totally blind or missing something but it feels like all I can get out is reflection, refraction and direct light… no the GI ?
Thanks guys!
(see corona is so awesome that I haven’t really needed to break up my renders yet :tongue: )
EDIT: aaand I just found the Indirect pass… my bad!
Ooooh… no highlight compression… Hmm :tongue: but that’s the coolest thing about corona! haha
Hi Rawalanche
two questions:
-disabeling HL compression= set the value to 0 or 1?
-Has Exposure, contrast and white balance influence aswell?
edit: typo
contrast, gamma (other than default), and highlight compression are only nonlinear parameters
OK many thanks
Keymaster
I left contrast, gamma and HL compression at 1.
Saved out as a 1 EXR (16 bit) with all the Cessential passes included.
In After Effects (linear workflow) opened the EXR and extracted all the different pases.
When ever I put the beauty pass on top of the extracted pases there is a difference in, I think, translucency.
Am I doing something wrong?
Could you post the OpenEXR file(s)? I can check in Nuke to see if it’s a problem in AE or with the render elements.
OK no problem
By the way I now it is huge, but I have a backplate shot with a Nikon D800…
here is the link to download the EXR
http://we.tl/STb1EK8kku
239 megabytes? Crikey.
Looks like it’s AdobeMath™ at work. Looks fine in Nuke, aside from a small fringing. Not sure why there would be fringing.
The attached images show the result from adding together all the render elements. The “difference” one shows the difference between the result and the main output, while the other one shows the comped and the main output spliced together in a checkerboard pattern. You can’t really see which is which.
OK so it is After Effects…:-
Thanks Captain
This is really weird. I have no idea what could be wrong in After Effects. My first thought was that it was treating everything as sRGB but “linearizing” with gamma 2.2, which causes a discprepancy in dark colours, but when I adjusted for that in Nuke, it made for a much much bigger difference. It’s really just the foliage that’s different between your images, and any kind of incorrect colour math produces a massive difference everywhere.
Frankly, just buy Nuke or Fusion. Or dig out an old Mac and look for a copy of Shake. Almost anything is better than After Effects for comping.
Ok I just found the poblem.
Apparently the opacity of my translucency layer was 50% 8-/
Thanks for the efforts, at least now I know I do not have to buy Nuke :slight_smile:
Ooops :slight_smile:
