No lights are showing up in render
I can’t seem to get any of my lights to show up in my render. I can’t get them to work at all. No matter where I place them or what I do with them it’s like they just don’t work. They worked at first and now I’ve even restarted my computer and it still won’t show up.
Have you made sure that the “Artificial Light Brightness” may not be turned down to 0% in the Atmosphere tab of our Visual Settings? That might be the culprit - If it’s not that, please send me a screenshot of your scene setup in SketchUp, next to Enscape where I can see the lights not working.
Thank you in advance.
Yes I made sure
I’m not sure what to take a screenshot of there are enscape lights in my scene and none at all in my render
Okay… so… my lights only work if my Artificial Light Brightness is not set to 0. Any explanation? This is too confusing.
If you set a brightness to 0, it usually means there is no brightness (in this case light) emitted anymore. Zero percent brightness here simply means zero percent light emitted by our artificial light sources.
Hope that makes sense.
ohhh i thought it was the opposite.
I see - Hopefully your lights are working properly again?
yes but are there any actual tutorials or directions for enscape objects?
Hello i am inputting the strip light i.e the rectangular light object in my sketchup but it is not showing in my enscape render.
Do you know any solution to that?
Here is for reference to my previous enquiry.
