Hi, I need help. I want to make a carpet with a texture of hair, for example, stains, squares and hairs have background texture. Whatever I use is not working for me. I’m doing something wrong. In the tutorials they give the material to the substrate and there it works. ¨
I apologize for my English is from the translator. Thank you
koberec.max (244 KB)
It is not going to work right now with hair and fur. The solution is to use Ornatrix or Hair Farm. We are working on a solution to this, as it seems to be requested quite a lot.
See: https://forum.corona-renderer.com/ Hair and Fur Map Issues
oh thanks
thank you
Hi Supakl, I want to use the default max hair and fur with the circular geometry and be able to manipulate the same parameters provided in hair and fur modifier rollout. Appreciate your time to respond on the issue.
