No panning in 2-point perspective+Vantage viewport
Pan is blocked in 2-point perspective+Vantage viewport. Could it be fixed please?
I am also having issues where the Vantage render does not match the SketchUp model behind it.
Hello juliaav and Matthew_Valero!
Mind that the Two-Point Perspective camera is currently not supported in Vantage. When the support is added, the Pan tool should also work.
I reproduce this behavior. We will investigate it further.
Thanks for reporting!
Kind regards,
Ivelina
Any update on this issue?
Hello, Matthew_Valero!
It is logged in our internal system as SK-5904. I will notify you when there is more information about it.
Regards,
Ivelina
Hello, Matthew_Valero.
It turns out there is an issue in Vantage when various cameras are used in combination with a Two-Point Perspective camera in the scene. This leads to a mismatch with the SketchUp model.
As a workaround for the time being you can try to delete the Two-Point Perspective cameras from your scene.
I hope that will help until there is a fix available.
Regards,
Ivelina
Thank you! I will give this a try.
