No refraction
  1. Seems that alpha3 doesn’t do refraction in case of filled refractive objects.
  2. Bottle and the upper cylinder has one material.
  3. And just renamed same material on cylinder. Cap remains invisible.
    2012max scene in attachment
noRefraction_bug.max (244 KB)
good catch! I tested even on the latest build and these confirmed!
There is a quite complicated system to determine which objects are on the inside and which on the outside. Looks like it needs some tweaking. I’ll do it after A4
Looks fixed. I’ve re-done the refraction system. Do some testing as soon as I upload a build
Thanx a lot!!! Now I can use the last builds!!!
thanks for fix, Ondra!
