No Render
I am having an issue. My material library stops loading and when I hit render nothing happens. I am running MAX 2009 on a Windows XP64 workstation with V-Ray SP-2.
No Render
Here is what is happening.
http://www.whitebirchstudios.com/public\_share/vray\_error/no\_render.html
I think if you show the little VRay messages window while rendering you’ll find that it says in red “error: Could not obtain a license (10061)”
Have you tried restarting your computer and also plug the wibi key into a different usb port?
check in your browser localhost:30304 if the license really is running
Kind Regards,
Morne
If everything seems correct, but you still have this issue, you can try to create an environment variable named “VRAY_CONNECT_TIMEOUT” without the quotes, and with a value “50000” again without the quotes.
v-ray
rebooting max solves it, but it’ll happen again. I’ll try the suggestions.
