No scroll bars on Vray 5 frame buffer image
I have noticed there are no scroll bars on the UI of the v-ray 5 frame buffer. Can we have those added back in?
There are many moments where I am checking renders remotely from a laptop and only have a trackpad. This means I have to use the +/- keys to zoom in and out, and then move the scroll bars to pan around the image. In vray 5 it is now impossible to move around once I zoom in.
Incase this is a Mac only bug, I included a screenshot below. IT is a 2k image zoomed in 400% with no scroll bars. Thank you for the help.
The arrow keys on the keyboard can be used to move the image. Does that work for you?
I can, but its pretty slow moving around a large image :slight_smile:
I see.
There are some options that control what fraction of the visible image is moved when using the keyboard arrows. Additionally, holding shift increases the step.
If you go to the Options menu of the VFB > Settings > Render View tab and enable “Show Advanced Settings” you should find this:
You can try increasing the pan display fraction. Increasing the shift multiplier specifies how much the step is increased when holding shift.
There’s also the option to use “VFB 3x pan”, which controls the pan in image pixels, instead of in display fraction.
Will this help in your case?
Thank you for this Alex.
