Ive had a sequence rendering for 24 hours, and not one single frame has output even though they only have 150pass limit. I keep getting this error on backburner.
I tried resending the job and deleting the elements path as It looked like from the asset tracker it was trying to save the elements there. This didnt work, as a test I tried delete all render elements (not really needed anyway for this pass) and it still wont render. It loads in the vfb, starts, but errors out along the way. Plenty of ram left, its only using 28gb of 64 so I should have enough. Anyone come across this issue?
It is defintely corona. Most likely a ram issue as the errors started happening during my render tests. I sent a simple scene forestpro on a plane at 6k. This renders. Then at 10k… then 16k… it does this at 16k. Im having unexpexted errors though as well as this which i can post tomorrow . Unfortunately over the years ive had little success with backburner s strange errors. Usually restarting the license manager or clearing data, restarting pcs or running as admin, updating backburner usually works but since im quite new to corona these errors are foreign to me.
Ok, in the OP you wrote about a “sequence” and I implied you are doing some animation. Trying to do a 16k render would have been some important information So all works ok until you go to 16k?
When you update the tread, please also add Max version/BB-version, free disk space on C:, and to quote Maru:
Yes, animation. Sorry for the confusion, I should have clarified “when doing my tests” was when I sent the 6,10,16k images to see if it was a memory issue. Since updating to 1.4 Ive had more success rendering the animation. Ill post back if it continues. Thanks for the help!
