No sutitable GPU device found! A DXR-compatible device is required.
I’m using GeForce 2070 Super 8G.
DirectX 12 in use
The nvida driver is up to date
Win 10 build is the latest.
80 Gb of memory.
cpu E5-2683 v4 @ 2.10GHz 2.10GHz(two processor)
What’s wrong with it that it doesn’t work?
(No sutitable GPU device found! A DXR-compatible device is required.)
Weird, it does look that you cover the requirements from what you say… Could you please provide the log file located at %APPDATA%\Chaos Group\Project Lavina\debug_log.txt ?
debug_log.txt
Lavina v0.5.0 (build 771736, hash f7952bfd)
Build date: 2020.09.02
Window initialized in 670.0 ms
NVIDIA driver version 8.17.14.5655 detected.
Driver check warning: Driver 456.55 is newer than the latest tested version which is 456.38
Windows version is 10.0.17134.
Device #0: NVIDIA GeForce RTX 2070 SUPER, 8011 MB (DevId=0x1E84, SubSysId=0x1E8410DE)
Device #1: Microsoft Basic Render Driver, 0 MB (DevId=0x8C, SubSysId=0x0)
Can’t use device #0 - no raytracing support (0x80070057). Skipping.
No suitable GPU device found! A DXR-compatible device is required.
Oh, I see. Your windows version is build 17134, a.k.a 1803 from spring 2018. Our minimum requirement is 17763, the autumn 2018 update which added DirectX raytracing.
