Hi, I just buy 1.0 and testing.
In Distribuited Render the nodes does not read the textures : (
No Firewall in any computer, no antivir, no problems with alpha 7.2.
Corona 1.0 - Max 2014 - win 7 Enterprise 64
Any idea ?
Any idea ?
are your paths set up correctly? See the troubleshooting section here for more info: https://coronarenderer.freshdesk.com/support/solutions/articles/5000501666-how-to-use-distributed-rendering-
The path was perfect, No problems inside 3dsmax, the texture does not load in DR : (
Solved, It was a windows file system Problem. I don’t know why.
Only in one of my render nodes we have the problem.
Thank you Keymaster.
Can you provide some more info? This may be helpful for other users with similar problems.
I remove the User Acces Control turn on “Acces is allowed with default setting” in the Privacy Policy.
And of course Disabled Windows Defender.
Otherwise TCP 1977 port error en DR server.
Got the same problem here, can you provide infos on :
Thx
OP solved the problem by himself. We added the missing files reporting to Corona for better solving of similar situations in the future.
