I enabled the Chaos Vantage toolbar in Sketchup, but no buttons appear. Has anyone else had this issue?
Hi calvin_ode,
When you enable the Chaos Vantage toolbar it doesn’t automatically pin itself somewhere in the toolbars, it is floating somewhere on the screen. Maybe it appears on a second monitor that it is just too hard to notice?
Alexander
If you are unable to locate a floating SketchUp toolbar, in this case “Chaos Vantage”, please go to the SketchUp menu View > Toolbars, then ensure it is enabled and reset it.
This should make the toolbar reappear somewhere close to the center of your main display.
Note that the toolbar consists of a single button so it might be hard to spot at first.
Hi @Peter.Chaushev , I tried resetting the toolbar and it still didn’t show up.
