No Vray with custom HOUDINI_USER_PREF_DIR
I have Houdini 18.0.308 working with the latest nightly vray_adv_43000_houdini18.0.279_20cdd59_5950. Nice!
But to easily manage multiple machines (workstation and rendernodes) with the same prefs, houdini.env, vray install,… I’m trying to centralize
I created a new User Variable for HOUDINI_USER_PREF_DIR with value E:\_Houdini\_Configs\houdini__HVER__
This seems to be working for the most part except for Vray. When starting Houdini, Vray has disappeared.
I noticed that, unlike earlier (beta)versions, with these newer installers, nothing is added to the houdini.env anymore. So I’m guessing I should look else where, but where?
Cheers,
Tim
Hey there,
package files are used when running the installer. Those are located in the Houdini install folder, e.g. C:\Program Files\Side Effects Software\Houdini 17.5.391\packages
Nothing has changed regarding the zip version - you can grab an example environment file from an old build, or check the unpackedZip/docs/vray_for_houdini.json file for the environment variables setup.
Please ping me if you hit any issues setting things up.
Cheers!
Hi Gosho,
Thanks for your quick response!
Simply copying these lines into the houdini.env did the trick:
# V-Ray for Houdini Begin
VFH_ROOT="E:\_Houdini\vray_for_houdini_18"
VRAY_APPSDK="${VFH_ROOT}/appsdk"
VRAY_OSL_PATH="${VRAY_APPSDK}/bin"
VRAY_UI_DS_PATH="${VFH_ROOT}/ui"
VFH_HOME="${VFH_ROOT}/vfh_home"
VFH_PATH="${VFH_HOME}/bin;${VRAY_APPSDK}/bin"
PATH="${VFH_PATH};${PATH}"
HOUDINI_PATH="${VFH_HOME};${HOUDINI_PATH};&"
HOUDINI13_VOLUME_COMPATIBILITY=1
HDF5_DISABLE_VERSION_CHECK=1
# V-Ray for Houdini End
Cheers,
Tim
