No particularly a bug but I remember it being different before:
I installed the daily build of Corona Renderer and since then my Corona shaders are found in a different section.
As you can see in the screenshot, I have to go to plugins → corona → and then select the shader, before it was displayed directly underneath MoGraph.
What the heck? I haven’t seen this before actually… Maybe this is automatically done by C4D if you have too many shader plugins installed? Maybe it then moves all the 3rd party shader plugins under the “plugins” folder in order to keep a compact shader menu?
Happens here, too.
I guess it’s a C4D thing.
In an installation of R20 with the Insydium bridge installed, it goes as far as to show two “plugins” entries in a section with the name of my user name.
I have always had the corona shader under plugins, I thought that would be normal. I’ll test that by disabling other plugins to see where the corona shaders are then.
Hi, if you have only Corona Renderer as a plugin (or Render Engine) C4D doesn’t create a group like this. But yeah its a bit annoying if you want a Corona Shader.
