I’m not sure if this is a known issue, but I can’t teamrender materials wich are build using corona’s node editor. Rendering on the local machine only works fine though.
See attached screenshots. On the comparison screenshot the upper half is teamrendered, the lower part is rendered on the local machine only.
I also uploaded the scene file via your private uploader: 1543318899_Teamrender-node-issue.rar
Hi, thanks again for the file. Not sure exactly why this is happening so we will need to look into that. Your workaround though would be to duplicate the nodes and link them to the displacement slot. It seems to render fine after doing so.
