Why did you remove the “noDecay” boolean in all the vray lights? Its still accessible via maxscript, this button used to be exposed but not anymore, and is very useful for lighting scenes.
And no, using default max lights sometimes is not the solution, since they dont work with fumefx or phoenix for example.
It was removed from the UI a long time ago. I don’t remember the reason - probably because it’s not physically accurate or because it created conflicts with other features. As you’ve already found out - you can enable it through scripting.
