Wow! That is fantastic work. Very original concept. I love it. Which compression method did you use? The motion blur really sells it as film.
h.264… Was a nightmare to get working though, I hate codecs ![]()
It is incredible though. Better quality than anything else, and much smaller file sizes at the same time.
m_hinks - Thank you!
I do a lot of tracking using syntheyes and on one of my last projects i had the same issue. It wouldn’t work on the edges at all. I tracked that footage about 5 times with similar results until I realized that it was because of the lens distortion. I am not sure about boujou but syntheyes has a little application that will remove the distortion from the footage. Everything was perfect after I did that!
And about the codecs, I’m with you! I had a lot of issues with the h264 trying to put together some frames. I’ve tried AfterEffects, Combustion and QTPro all using the same settings for the codec. AE and Combustion were looking crappy and much larger file size than the QTPro!!! I guess it’s a matter of implementation…
Stunning work all round, especially given the 4 week time frame. Loved the lighting!
Download ffdshow on free-codecs.com or the stand alone x264vfw.
h.264 is incredible I must agree, started to use it too, unfortunately there are some problems with sharing it with others. the h264 in quicktime is very good too.
You get an ‘awesome’ and a thumbs up from me.
The only thing that lets the whole animation down is her eyebrows.
That is f***ing excellent!
You say that you just did some colour tweaking in Combustion but I see some nice aberration, especially in the reflected Sun… Was that not done in post? Or is that the color tweaking you are on about?
Anyway, hats off all round!
Yeah - thats from one of the sapphire lighting plugins - it’s the one that pushes all the reds and blue’s out but if you put a black & white vignette mask into ‘lens’ it gives a really nice aberration effect. That, sapphire glow and the standard combustion colour correct is all I used on the 3d.
And thanks! - means a lot from you as it happens, I remember back in the board of biffo days when I was first starting I was blown away by your work and you made me want to get good, haha.
just out of interest how did you do the people? they rendered separately, are they 3d people or just 2d maps?
Shit, forgot about those - I said I didnt do any comping and that was a lie.
They were RPC’s, rendered on their own with all the other objects having a mtl wrapper on so they’d mask out, then thrown over the render layer.
The scatter plugin working with rpc’s was a godsend :lol:
Yeah this was definitely one of my favourites from the cgarchitect entries. Really nice integration, quality and finish.
Fantastic work, nice and clean, wow everything is spot on.
Well done.
Did indeed - some of the shots were done in reverse just just because it’s easier to destroy something than it is to create it. The particle flow for the main tower/3 offices shot is enough of a mess as it is.
The client actually named that shot ‘boomshot’ when they sent the frames over :lol: Guess it was too late to do anything about…
Hahah nice one on spotting the boom mic. The number of times i’ve annoyingly poked people in the cinema or whenever to say i’ve seen a boom. Pretty sad really! That and cameramen in reflections.
Amazing work - I’m inspired to try particle flow now! I worked through a couple of basic tutorials I found online the other day but I’m wondering if there are any tutorials covering anything more complex such as the buildings you did. How can you get all the windows/panels flying in and landing in the correct location? When I tried using Pflow I realised you can make the particles any required shape but it seemed random as to which order they land, even if you have a template for them to follow. Thanks for any help…
I assume that they did an inverse animation…they the have the panels in place and after that they make fly them, then you inverse the keyframes.
P.D. Thanks Joost ink, I downloaded the h264 code and it works great!!!
Do some research on Birth Script. It is a rather simple bit of scripting that will place particles at specific locations; such as at every vert or every poly center. Then take a clue from the collision objects comments. Spend a week or so and try and figure it out on your own. You will learn so much. If you are not a scripter (I am not either) it will take some time to learn a little scripting but it will really pay off in the end.
Oh, and no reverse animation necessary… ![]()
Brilliant, thanks very much - birth scripting here I come ![]()
I’m interested to know the shutter speeds you used on the vraycamera to achieve that level of motion blur.
