noise IBL vs Corona lights
can anyone tell my why there is this big difference in performance between IBL and Corona lights?
When using same number of passes, the IBL approach is noticably more noisy.
image based lighting
so hdri or exr in environment map slot … exactly as you said
now when I’ve been rendering images to better describe the “problem” everything seams fine… I think i had checked rendering by time rather than individual passes, so that caused the problem
but still, speed is an issue when using HDRI vs lights
i can provide the scene max 2014 … without the model that is
