Hello everyone.
Need some advice for this animation. Especially for the noise on the building which is not lit by the sun.
Also on the “flicker” railings.
I addet a short clip and screenshots of the settings.
I was thinking, a noise level of 2.5 would be enough to solve that but it don´t.
Frames have been rendered on Renderfarm.
I don’t really see any incorrect render settings in your screenshots.
The attached avi does not show much noise or flickering, or at least I cannot spot it.
In the stills, it looks like regular noise smudged by the denoiser.
Render out a few frames locally (not on the farm) with Intel AI denoiser instead of the Corona HQ one (this is mostly to compare which one does a better job in this case)
There could also be some kind of mistake in the scene setup, however that would require checking the scene itself. If you wish / are allowed to, you can share it with us. The uploader is in my signature.
