Hi, I’ve attached an image I’m rendering. It seems to have patchs of noise that are rectangle. On the opposite side of the wall there are windows that are this shape. I’m using the glass material from the Corona material pack. Does anyone know how to fix this noise?
You could try as burnin’ has suggested. It’s hard to really know without seeing the file. If you can share that with us, please feel free to use the Corona Support link in my signature below.
Removing the glass or disabling refraction is still a workaround. It would be good to check the scene and find the root cause of this.
Maybe there are some environment overrides used, or some other non-physical effects that are causing the extra noise?
You can attach it in the ticket submission form: https://support.chaos.com/hc/en-us/requests/new
Alternatively you can send us a ticket without the file, and then we will contact you with instructions how to attach it.
