Noise in reflection pass
I am experiencing lot of noise on the reflection pass.
I always use the High-quality preset, then go to manual and increase the samples for reflection and refractions, but still I get this type of results.
What settings are recommended or what else should I do to get a clean reflection?
Thanks.
Currently the render elements will be noisy as they are not denoised as we do for the Beauty pass. You can vote for it here : https://chaosvantage.ideas.aha.io/ideas/VANTAGE-I-201
You can try to get a better quality for the REs by setting higher value for the Samples - make a test with 1000 or 2000.
