Noise in scene interior archviz
Hello.
In this scene, i have lote of noise, in 100 passes. My tests show me have noise in 300 passes or more…
Lights: This Scene contain only 4 light corona and Corona Sun /sky (no hdr)
Material: override white.
1 Corona Material (eclude from material override)
1 glass thin (exclude from material override)
I have noise in direct light.
Have noise in Indirect Light.
All config are default.
Have you seen this article on Noise?
https://coronarenderer.freshdesk.com/support/solutions/articles/5000501983-how-to-get-rid-of-excessive-noise-
Helllo. Thanks for help.
Yeah. I read this article.
My scene have correct albedo (no red albedo). ( This noise appers in material override with correct albedo - white albedo - )
Its noise dont provide from material (because all scene have override material)
I have only 4 lights in scene… and i have noise in indeirect light and direct light :frowning:
Are you using portals in this scene? Be sure to use them: https://coronarenderer.freshdesk.com/support/solutions/articles/5000501660
You can also try increasing GIvsAA to 32, and leaving LSM at the default of 2. This should give you better GI quality at lower amount of passes, and in a shorter time.
You can also lower MSI (https://coronarenderer.freshdesk.com/support/solutions/articles/5000515636) to 10, but it will most likely affect the lighting in your scene.
