Noise level limit and denoising issues
What is the relation between noise level limit and denoising ?. When denoiser is enabled with noise level limit the render take very long time in each pass to reach the noise limit ( it takes forever I usually cancel it ) but when I disable denoising it works as expected. As I understand the denoiser is just a post filter calculated after the render is finished isn’t it ?
could you please try the latest daily build? It’s most probably fixed.
What build are you using? I noticed this issue with build 04-29 IIRC, but in RC it was fixed.
Yes I was using DB 01-05-2016 I will download 1.4 RC2 and try again. Thanks guys
It works as expected now in RC2
