Tried searching but couldn’t find anything.
Is it possible to allow the noise level in the stats of the framebuffer to display more than 1 decimal place when the noise gets down to 0.0% ? . for example once it gets below 0.1% can it start reading 0.009% and below rather than just getting stuck reading 0.0%.
I say this because a new scene I’m working on quickly got down to 0.0% noise after around 100 passes, but after being left for 500 passes its much cleaner but still reads 0.0%.
Not a problem if you’re sat at the computer, but when using teamviewer to check on a render its impossible to judge the noise visually and the noise level readout can’t be relied on when its already down to 0.0%
