Noise on reflection pass
hi,
most of the time, the vray default settings works for me… until this scene.
I’ve attached the passes showing the problem.
I really apreciated any help you guys can give me.
thank you
I’m on a deadline
I’ve sent the file to support.
Looks like your min subdivs in dmc are set too low. What are your settings?
adaptive 1-24
color treshold .01
noise treshold 0.005
msr 6
reinhard color mapping
burn value 1.0
thank you
Yeah so you need to put adaptive to higher then 1, say 2, and lower clr thresh to 0.007, also probably lower msr to 3-4 and raise max from 24 to 32…
If it doesn’t work send me a link to the scene (can be simplified) and I will have a look.
