noise problem!help me .
these an two images,with different parameters.i dont know how tis connection.why the first image have noise but the second have no .do you tell me whats wrong with its . and how to ravel out the problem .thinks!!!
Jesus …where did you get those setting’s from … no wonder that took 9 hours !
QMC reset that back to standard … 1.0 .. 0.8 mins sample 15.
Your Imap setting are all wak… set it back once again … just go for a medium setting !
Clr = 0.3
Nrm = 0.3
Dist = 0.1
you know what, set it all back to standard … and render … you will get a better result..
Photons .. Bounces should be the same as Interp sample !
9 hours :shock: :shock: :shock: :? :? …damn…that’s crazy…especially for such a simple scene..
paul.
